Hello fellow Hp Tuners. I've just started a tuning project. pretty new to tuning vehicles personally but have some assistance on hand from a tuner whos not famiilar with the HP tuner platform but given time will work it out... but to save some time... im in need of a stock SC Base map for a LSA SC motor running on w E67 ECM.
Engine: CTS-V LSA, fitted with an upgraded Magnuson TVS2300 Heartbeat SC, KPW Streetfighter 1500 fuel pump, fuel injectors ID 1500XDS, and running a Vaporworx Fuel controller. running off Map.
the vehicle was supplied with a stock crate LSA motor and E67 ECM which appeared to be configured for a NA engine. we have recently fitted those upgrade parts mentioned above as the stock items were not up to the task. we are looking at approx 700hp when finished, as engine enternals have not been upgraded yet.
i now have the engine up and running and vehicle driving, but far from finished.
if there is anyone out there with a base map for a SC LSA motor in any spec, i could use for comparison that would be greatly welcomed to compare.
great thanks, ive finally found the Repository section downloaded a few stock fines to compare against, thanks guys for your help should be good for now.
