Results 1 to 14 of 14
Thread: LTFT and PE Confusion
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    513
    Question LTFT and PE Confusion
    I have heard that the current LTFT correction will be utilized once you transition into PE, positive or negative. And I have also heard LTFT will only carry over if it is positive (meaning you are running lean). Are either one of these statements correct?
    I am working on an E38 if that makes a difference.
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    I don't know for a fact, by personal logging.
    But from what I'm told by very reliable sources is If you are lean going into PE it will command PE plus your lean error.
    If you get your trims in order I really don't think its anything to be concerned with...
    (Bluntly if you are so far off with fuel trims entering PE, PE is your least concern).
    Do you have a specific issue you are chasing?
    RPM and TPS delay in some stock tunes really inhibit PE
    2011 Camaro 2SS Convertible L99 Bone Stock for now
    2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
    Aug 2021
    513
    I'm not experiencing any issues, just new to tuning. I see so many professionals and amateurs alike disable them and it's always the same story of "if you're tune is dialed in you don't need them." Well ok...but to me that's not a real answer and IMHO can set you up for trouble later. The only real counter argument I've heard is the prevailing LTFT value carrying into PE...but that seems like an urban legend that keeps getting repeated.
    Jun 2015
    Aubrey TX
    890
    Quote Originally Posted by Cringer View Post
    Got Ya..
    I wish I could give a definitive answer, and now I better understand your question, and agree with your analogy for setting yourself up.
    I know there are people here that know that answer.
    I'm guessing if you posted the question " Does LTFT error transfer to PE and effect the commanded ratio, Positive or negative"
    Then in the body of the post ask "if you disable LTFT, but keep closed loop, will STFT still transfer the same error"?
    "Or do fuel trims in closed loop effect PE at all"?
    Jun 2015
    Aubrey TX
    890
    I'll keep watching this, and if you start a new thread and don't get any response, PM me and I'll PM the thread to someone who I know can answer
    Jul 2020
    VIC Australia
    1,157
    My logs show STFT goes to 0 and LTFT stays rich. Have never seen the LTFT stay lean. If I switch off LTFT I notice a couple of point change leaner on my wideband.
    In my experience (E67) yes the negative LTFT carries over and will richen up your PE. I can't say what happens if LTFT is positive as I've never seen it in my own logs.
    Jun 2015
    Aubrey TX
    890
    Quote Originally Posted by hjtrbo View Post
    Did you mean Lean fuel trims will cause PE to richen up a bit?
    They way I read your response (which I respect) is negative fuel trims (rich) carry to your PE and increase it a bit (richer)?
    That is completely backwards from what I understand.
    I've been taught that if you are lean going into PE the computer will command your PE "PLUS" what ever lean value you were running
    Thanks for jumping in here!!!!
    Tuning Addict
    Jan 2015
    6,802
    Some early or odd ball gen 3's would carry positive and negative trims into PE. That's where the whole "disabling" ltft's started and probably where the confusion is coming from. On gen 4's only positive long term fuel trims will carry into PE and change PE fueling. Same goes for gen 5's too... Hopefully this will clarify some things. I think hjtrbo just mistyped as the way I read it, it's backwards...
    ~Greg Huggins~
    Jun 2015
    Aubrey TX
    890
    Thanks Greg
    Tuning Addict
    Jan 2015
    6,802
    No problem... AND to further clarify in case there's any confusion here for the OP - positive trims are trims adding fuel - long terms of these are what get carried over and used to modify PE fueling. Actually knew a "tuner" back when that didn't know what + or - trims actually did. He just tried to get them close to 0...
    ~Greg Huggins~
    Jul 2020
    VIC Australia
    1,157
    Yes sorry gents my bad. Leaner trims adding in fuel.
    Jan 2014
    Australia
    1,982
    then there are the odd ball e38 where some STFT will carry over to PE even with LTFT disabled, i would always get a different PW bank to bank if i was CL STFT only and it reported a couple % on one side STFT before PE, soon as im full OL going into PE was same PW for both banks
    Aug 2021
    513
    This is a Holden-ized E38 from a MY14 Commodore (but in Chevy SS trim).
    I have read you statement a few times, trying to decipher it...I think I understand what you are saying...but wouldn't the PW *always* be the same bank to bank during PE, regardless if one or both short or long terms were disabled?
    Jan 2014
    Australia
    1,982
    im not sure what actually going on but i think most if u use fuel trims it would be a bank to bank error correction, unless its just an odd error in the OS
