Results 1 to 8 of 8
Thread: lean code issue
    Jul 2021
    V.A.
    5
    lean code issue
    2011 5.3 having lean codes P0171 P0174. and the truck doesn't run like it used to it drinks gas bad. we put new gm intake gaskets, new maf sensor, checked ohms on injector, checked injector orings, replaced the driver side valve cover, and prayed carb cleaner around intake no change in rpm, I've attached a data log any info I would appreciate it.
    Jul 2021
    V.A.
    5
    *correct data log*
    correct data log
    Tuning Addict
    Jan 2015
    6,814
    Just a couple of thoughts since don't have a tune or anything to go by. It looks lean, substantially so at points and then goes back to normal like fueling. Are any codes at all set? Does it sputter at idle particularly at any time at all? Idle weird at times? Engine make any noise or getting gas at a different "cheaper" station recently?
    Check to make sure your MAF is clean. Check to make sure your plugs are good. Check to make sure your purge valve isn't leaking. Might also want to check fuel pressure with a gauge while driving and hitting wot...
    ~Greg Huggins~
    13,565
    Smoke test for leaks.
    Jul 2021
    V.A.
    5
    the only codes i can get it to set are p0171 and p0174 and the rarely seen p0300 and it does have a random rough idle in park after it gets to operating temp. engine sounds good and acts healthy still pulls good and starts fine. as far as gas goes I fill at one place and use 93 since the build. I really do appreciate all the help sir.
    Jul 2021
    V.A.
    5
    is there any areas i should look for in particular when doing the smoke test ? or places i can check before i go get one done ?
    13,565
    Intake gasket area, injector o-rings, brake booster fitting, map sensor seal, exhaust manifold gaskets and y-pipe connections.
    Those are the most common spots.
    Tuning Addict
    Jan 2015
    6,814
    From the looks and sound of it, especially with it "drinking" gas it's most likely a vacuum leak. Throw in the random misfire code setting at idle and the fact that I am "assuming" your checking and clearing codes as they're setting, I would say you either have a brake booster issue as previously stated or a stuck open purge valve. The purge valve will "usually" set unwanted flow codes, but that's if you haven't already deleted some of the evap codes or don't have other evap issues like a vent valve that's not sealing (fuel tank has to see a vacuum being pulled on it to set the unwanted flow codes).
    Other things that will cause this - air leaks on the engine itself - ie oil cap, broken or missing dipstick, cracked rubber breather plugs around the intake or valve covers or seals or gaskets on the engine in general.
    Smoke test will show all of these although you can test while watching fuel trims and then unplugging and plugging off hoses by hand - basically any line attaching to the intake. I would go straight to the purge and brake booster first, then start really digging deep for the other hoses and connections.
    ~Greg Huggins~
