Results 1 to 3 of 3
Thread: 1000rwhp ctsv E67 ecu, 2 bar OS fuel cut issue.
    Aug 2014
    NC
    37
    tuning a 2011 ctsv with twins, ive done dozens of 4 digit hp sbe ctsv2's but this may be the first one that ive had crack 1000 wheel on a 2 bar OS enhancement.
    with up to 9lbs on the gate shes fine pulls clean, makes 18 psi or 230 kpa, and no issues pulling to the limiter at 7400, and make about 1020rwhp
    throw any more pressure at the gate to raise boost even just one psi, it hits a weird fuel cut, sooner the boost ramps in the earlier it happens.. when it happens it drops it drops current inector duty cycle by approx 65%.
    boost limit fuel cut disabled
    all tq limit fuel cuts disabled
    fuel cut tq mgt type= none
    trans tq mgt type = none
    all prediction coefficients zeroed out
    maf signal wire pulled or not does not matter
    maf sensor state stays "failed"
    0 or maxed maf curve makes no difference
    cyl airmass registers 3.3 to 3.5
    back to back to back test.
    please help
    Tuning Addict
    Jan 2015
    6,844
    max map and map axis is set to 255? I assume so, but just asking.
    ~Greg Huggins~
    Aug 2014
    NC
    37
    correct
