Results 1 to 6 of 6
Thread: Challenger srt8(6.1L) with magnuson supercharger
    Oct 2021
    6
    Hello everyone.
    I ran into a problem while setting up the dyno. After 4000RPM, the control unit hits some kind of limit and turns off the fuel supply. The problem is floating and does not always appear. Down two logs, one is fine, and the second is with an error. And the firmware file. I would be grateful for help in finding the problem.ChallengerSRT_WOT_tun_mod10.hpt
    run14_554whp.hpl
    run18_error.hpl
    May 2018
    Germany
    590
    your fuel would be cutted. It fgoes from 12 ms inj to 0 !
    Maybe torque management.
    Nov 2009
    All Around
    3,149
    give this a shot
    ChallengerSRT_WOT_tun_mod10_MAS.hpt
    with boost i like to rescale injectors as well
    Oct 2021
    6
    Quote Originally Posted by SultanHassanMasTuning View Post
    give this a shot
    Hi,
    tried your solution, same result((
    I can't figure out why the airflow value is so low?
    run8_limiter_mod_throttle_airflow.hpl
    run9_faile.hpl
    Tuning Addict
    6,858
    Minor change for you to try.
    ~Greg Huggins~
    Oct 2021
    6
    Thanks, I'll definitely try it.
