Hello,
Been a lurker for a while, first time posting.
I'm working on getting a freshly built motor in my 04 suburban to run. its a pretty conservative build: stock 6.0 LQ4, a BTR stage 2 truck cam, 317 heads, and a Dorman 615-183 truck intake. I know these trucks almost max out their injectors and I have a set of 50 lb flex fuel injectors to go in but right now I just want to focus on the small stuff and get comfortable with the program.
So far the truck starts up, runs, holds a steady idle, and drives without needing pedal or help. I set the idle up with suggestions I saw around here as well as some other places, namely idle increase and timing as well as airflow. But its mostly all ballpark figures I need to fine tune.
I'm working on getting my wideband hooked in today and working on part throttle tuning, attached is the current tune if anyone wants to provide feedback.
