Results 1 to 10 of 10
Thread: 2011 Silverado 5.3 to 6.0 swap... HELP PLEASE..
    Jun 2020
    7
    Dropped a number 7 LS7 lifter in my built 5.3 and lost oil pressure... Recently dropped in a fresh LY6 and 6L80 with a Billet converter and the typical upgrades...The 6.0 has new internals, BTR Truck Norris Cam, long tubes, off-road Y pipe... I need help tuning the transmission and engine... I'm having some very stupid problems and trying to work out some bugs... Any and all help is greatly appreciated!!
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Post up your Tune (Read from whatever ECM you are using)
    What did the LY6 come out of? I did a quick search and seems it only has 29lb injectors.
    Everyone here says that with a Cam you will max out those injectors...
    2011 Camaro 2SS Convertible L99 Bone Stock for now
    2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
    7,715
    Eh... Gen4 29lb injectors aren't as much of a problem, it's the non-flex Gen3s that have 25lbers (and especially 21lb in the early models) that are quick to get all used up.
    Jun 2015
    Aubrey TX
    890
    Thanks!!!
    I though 36lb was preferred
    7,715
    29s should be good for 430-440hp at the crank, maybe a bit more. The Gen3s are out of injector if you look at them funny.
    Jun 2020
    7
    Quote Originally Posted by dhoagland View Post
    I'm using the LC9 Flex fuel injectors from my 5.3...
    Jun 2020
    7
    My current Tune
    Jun 2020
    7
    I also need help with my transmission... Billet single without stall converter.. Boost valve.. TCC Valves.. Sonnax 4-5-6 Piston... Raybestos Steels and Clutches.. upgraded 1-2-3-4 Piston
    I'm unsure about the tuning everyone is talking about with only commanding lockup in 4 5 6
    Jun 2015
    Aubrey TX
    890
    This is how to set convertor to lock 4 5 6 only.
    You need to change your Cylinder Volume For 6.0
    What problems are you having?
    Con you post a log file.
    Jun 2020
    7
    I changed the number of cams from 0 to 1 and I believe that's the reason for the P0010
    I Bumped up the range for the misfire count and also changed the MAP from fast to Slow sampling and haven't seen any current misfires on my scanner but the codes remain
    The rest such as the brakes is my main problem.. I have chased every ground and even replace the fuse box due to corrosion...
    I will try to log a short drive tomorrow
