Open loop tables for gas and alcohol are all set to .95 I cant figure out why my commanded lambda is ranging from 1.02 to 1.05 the longer it runs the leaner it commands! Wb reading starts at .96 and slowly leans out to match the commanded 1.02 to 1.05
And yes it is running in OL while I?m having this issue
When Its in closed loop its fine with a commanded lambda of 1 and WB reading of .99-1.0
completely stock L76 other than a mafless otr I have the 2bar map os patch applied although it makes no difference it still dose the same thing with or without the patch
I have a vcm13 cam and full 3inc exhaust with extractors and ported Ls3 heads to go on over Christmas
Current tune is chopped up trying to fix the issue so no point posting that just hopping some one has had a similar issue
