Results 1 to 3 of 3
Thread: engine swap and can't disable traction control
    ls3 engine in 68 gto using 11 denali 6.2 ecu. has 4L60 on a t42.
    anywhere i can find mention of torque or traction control, i have what i think should be off but as soon as you flat foot it, there it is. it's flapping the throttle open and closed and you can absolutely feel it.
    i don't even understand where this is coming from because how would it know it needs traction control? i've raised all the torque limits i can find as well.
    nothing seems to fix this. would like to do a burnout...
    any help is appreciated.
    7,649
    It's not traction control.
    P0010: Camshaft Position (CMP) Actuator Solenoid Control Circuit
    P0122: Throttle Position (TP) Sensor 1 Circuit Low Voltage
    P0223: Throttle Position (TP) Sensor 2 Circuit High Voltage
    P2122: Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
    P2127: Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
    Your pedal, throttle body, and calibration all have to be compatible, and the components have to be pinned correctly.
    swap so no cel light...
    sorry
    cam. ok. set to 1 vct. will disable.
    i don't know what pedal is in it. pull # and find out.
    might only need vct, let's see.
    thanks on this!
