Hello, i'm new on this forum,
I have problem with my Corvette c6 Z06 2006 after stage 4 install. Install himself because i'm from France. I have a map from Race proven Motorpsort. The car starts well (better when cold) and keeps idling well, but if I touch the Accelerator, the engine revs too low or stalls.
I tried a neighborhood tour, but the car shakes a lot at low speed (between 1000 / 2000rpm)
The richness at idle is top (lambda at 1) (Lambda probe on external box)
I suspected an intake leak. I completely disassembled the MSD intake and reassembled with joint compound on the joint faces. But same problem. SO i think it's just a problem of calibration.
My configuration (just mods rest is stock):
-280cc cylinder heads from Race Proven Motorsport
-Camshaft B3 (243/259 at 0.050 lobe separation 114 lift 0.666 at 1.8)
-2 "ARH headers with catasport and Borla catback.
-103mm MSD intake with 103mm Nick Williams TB
-HALLTEC killer Bee MF108 air filter
-60lb fuel clinics injectors
-Monster clutch S series bi-disc clutch with lightweight flywheel
-ATI Damper Pulley without overdrive
Somebody can help me?
Log and calibration (base and rpm cal) in attachement.
