2014 ctsv (m6) NW103 tb and ddp intake idle tuning
Hi guys, so I just installed the NW103 and the ddp intake (coming from a 90mm tb and airaid). I'm stock heads/cam at the moment. I increased the etc scalar to 7281, added 20ish% to the maf and 20% to the final min airflow table. It actually idles very well (like it did prior to installing both parts). My question is should my "idle follower airflow" be close to zero while idling or should it be somewhat close to what the "desired airflow" is reporting? I thought the "idle follower airflow" was an "adder" to the final min airflow table, but I could be wrong. I checked one of my previous logs prior to the 103 and ddp install and the follower airflow was reporting somewhat close to the desired airflow. Also any other tips to tuning this combo or things I should be monitor would be appreciated!
102 and DDP good idle with Min airflow at 8g_s at 650rpm.hpl
