Results 1 to 7 of 7
Thread: Need help LS swap fuel issue
    Nov 2021
    4
    Hello all. I'm in need of some help... I've got a LS swapped Canyon that needed a new motor. Now that we've got the replacement motor in I can't get it to start. I did make some minor changes but I don't believe they would cause my problem. I went from a flat top piston to dished and 317 to 799 heads decked .010" with a turbo cam. Original cam was a Ly6 cam I believe. Other than that it was just a straight swap. Same intake, injectors, rails, harness, computer, tune, etc. The truck literally was driven into the garage to pull the motor. Now after its all back together it's in reduced power, I've got no throttle body response, and the injectors only spray for a split second. Oddly enough the truck will run on carb cleaner. I've checked the grounds, replaced the oil pressure, cam, crank, and map sensors. I confirmed I've got fuel during cranking. The injectors have 12 volts (10.5 during cranking) but when I check the injectors with a noid light I get nothing. Could be a bad tester from the auto parts store maybe?
    I'm located in Lutz FL if there's any guru's local.
    These are the codes that I have
    0x7E8: P0053 - HO2S Heater Resistance (Bank 1, Sensor 1) (Permanent)
    0x7E8: P0059 - HO2S Heater Resistance (Bank 2, Sensor 1) (Permanent)
    0x7E8: P0107 - Manifold Absolute Pressure/BARO Sensor Low (Pending)
    0x7E8: P0532 - A/C Refrigerant Pressure Sensor A Circuit Low (Pending, Current, Old, History)
    0x7E8: P1682 - Driver 5 Line 2 (SES, Pending, Current, Permanent, History)
    0x7E8: U0109 - Lost Communication With Fuel Pump Control Module (Permanent)
    13,565
    Kinda sounds like a VATS issue if the fuel just shuts off.
    Nov 2021
    4
    my bad forgot to mention vats is tuned off
    13,565
    Was the VATS done with a write entire?
    You really gotta post the tune and logs too if you want us to see what you see.
    Nov 2021
    4
    I have no idea to be honest with you.
    Ok. I'll post the tune in a min. As far as logs I'll see if I can get some quick or find the ones I did a few months back.
    Nov 2021
    4
    06 Canyon Original Tune.hpt
    this one is from tonight
    Log 5.hpl
    Jan 2012
    South Dakota
    44
    Your speed shoots up to 158mph. Definitely a communication error. Double check all your wiring
