Been pouring through threads all over the internet to no avail seeing if I can get some help from you guys.
2011 silverado 4.8 w/E38
7875 on3
BTR Stage 2 Turbo Cam
243 Heads/LS9 Gaskets
Dual walbro 525 return style system w/boost refrenced regulator
GM zr1 map
No MAF
REAL BOScH 210s not knock offs
i used injector data for id id2000s on ID's site. Cut the flow in half and double stoich. Cut IVT terms in half.
Truck will crank and fire but refuses to idle.
i had the fuel pressure set at 43.5 with vac hose off but did increase it to 58psi to see if it changed any.
i have looked through so many threads my head hurts there is so much conflicting info.
can someone please look at my tune and see if im missing something any help would be greatly appreciated.
ps all im trying to do is get it to idle and move around so i can double check everything before i head to the next dyno appointment. i will include the original tune with the deka 80s i was running before i made any changes. along with the one i scaled for the bosh 210s2011silveradoturbodeka80.hpt2011silveradobosh210s.hpt
