Hi Guys,
I bought Hp tuners for my trans am some years back(2000 Ls1). I have since gotten a new project car. I've dropped in a custom built LS3 which has MAP Sensor #55573248 in the intake. I've scoured the web looking for MAP sensor calibration data and all I could find was .5-4.5V and 0-130 Kpa. I would think this should work. I've driven the car a bit and my MAP readings seem to be off. Sitting in the garage, my atmospheric pressure should read around 79Kpa( I live at 6700 ft elevation) and the Map reads 86Kpa. Also, when I back off the throttle the Kpa reads 0 and my ECU cuts fuel completely thinking I've got no air. Since this was a total custom build I'm running Holley terminator software for this particular build. Do i have the wrong calibration data or is there something I should be checking? I've gotten zero help in the Holley forum and I was hoping this forum would provide a bit more technical help.
I really hope someone has dealt with this issue before.
Thanks guys
