Trying my first time to copy/paste a 6.0 tune to the stock ecm. Copied everything over from a ly6 tune because I was under assumption the new engine was a ly6. Seems to run just fine besides cold start.
It surges at idle on cold starts as the timing starts out pretty low and then jumps up and down into the negatives pretty quickly. Only things not changed over on the tune is the map sensor since the original one from the 5.3 was used, and also the electronic throttle parameters were not changed due to the warnings that it can harm the ecm.
Not sure if its trying to use spark to control the idle since it has the TB from the 6.0?
Weird part is if you turn the truck off and restart it, it idles just fine.
Come to find out this new engine is a l96 and not a ly6, copied over a l96 tune, and the truck would only crank, no start.
Here's the tunes I'm working with, hoping I'm just missing something dumb here. Didn't save the log. Ill have to wait for it to cool down again to get one.
