I've got a TT'd 06' ZO6 using the VCM suite. Tuning has been limited because there are no VE tables for this application to dial in the set up. Of course I didn't realize this before I purchased . The car is running, but it really needs fine tuning. Car is running on injector scaling and PE tables. Idle is erratic and fuel curve is less than optimal. Car has an LPE 100mm maf and with the scaling they said to use it was grosely over rich so the maf scaling was altered to get the car in range. LTFTs are in the -13% with 60lb/hr injectors. When can expect VE tables?
