I have spent weeks on weeks messing with this tuning i i can't seem to nail it down. I posted my stock and current tune and log. my process of tuning is this.
I copied high to low octane table
turned off all DFCO
set PE at 100% tps and 4500 rpm " to keep out of PE"
EGR is inop "removed" from truck and disabled in my DTC's
here is the deal for VE tuning i tried fuel trims by taking the LTFT trim histo "usally set filter at 25 cell hits" and applying it to the ve table both single and double fire by paste special multiply %, then use the smoothing feature, save and flash, it seems i end up chasing fuel trims all over? any ideas, i cannot turn off ltft's or stft's and i cannot reset fuel trims. could this play a part? also as you look i do not have near as many parameters as most vehicals. am i asking to much to get my ltft's below +/- 5? i even tried a histo set up " off a post on here" of setting up a custom histo of LTFT+STFT and using that. which should i use LTFT or STFT+LTFT?
ok i have basically done the same with my timing, i log KR take the highest values and paste special them onto but high and low octane tables. i still end up with kr!!!
heres the killer, bought a wideband LM1 and got it all set up and caliberated to match with my hptuners! now i set my OL/CL temp to 260 to force OL
i then get a commanded low res. of 14.20 AFR. where did it come up with that? if you look at my base AFR it's 13.0 why the difference? ok i set up my AFR error histo, i then would set the filter to 50! take that logged chart and apply it to my ve double and single tables. I finally got it around +/-2 and saved it, enabled Closed loop, now my trims are back jumping around?
Sorry for such the long post but you people are making a great tune in a couple hours........i am sinking still with weeks invested. PLEASE HELP ME give me a step by step, if possible
