Hey Guys,
I am running out of ideas and would appreciate any insight you may have.
I have a 2011 GMC Sierra 5.3L and it has the occasional Ethanol Fuel % number that goes crazy high (59% this last time) and starts causing cranking issues. I have never used anything but regular 10% Ethanol fuel in it. Other than this my truck runs perfectly. 100% stock with no crazy mods.
I have been researching the problem for quite some time and want to fix it instead of taking it into the shop where they just reset the % back to 0 and it runs fine for a few months for $100. I bought HPTuner and have made the following changes. Disabled AFM, Disabled the Master Switch for Flex Fuel, changed my Stoich tables to 14.7 across all values. Things seem to run fine now but after a few trips my vehicle throws DTC Check Engine codes P0171 and P0174 System Too Lean Bank 1 and 2.
I have checked for vacuum leaks using carburetor cleaner, cleaned my MAF and numbers look fine.
Is there anything else that I need to do in addition to my steps above to successfully disable Flex Fuel?
Are those error codes valid or just a symptom of my changes that now need to be disabled themselves?
Any help would be appreciated as I am stuck.
