Results 1 to 6 of 6
Thread: Need help
    Nov 2005
    Someplace high in the Himalayas
    770
    Need help
    Have a 408 with big cam 3000k stall. When you put it in gear the timing goes to -5 to 15 and it won't run. Idle somewhat ok.
    Anyone have a file I can look at that would be a good starting point for a GTO?
    What should 408 in cylinder size read? 0.83575?
    .373 gear, 3000k stall, fast intake, 60lb injectors, headers,103mm tb heads are cnc'd and flow 340.
    I looked in the tune repository, but there only appears to be stock tunes in there anymore.
    www.outlawpontiacdragseries.com
    Come race with us in MA, PA, and VA!
    2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
    Stock:13.36@104
    Mods in sig:[email protected]
    Aug 2009
    Calibrating
    3,373
    What size cam and what’s the KPA at idle
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Nov 2005
    770
    I sent you cam info in email.
    Nov 2005
    770
    Kpa at idle is 65 to 70. Do you have a tune that is close? Thanks
    Nov 2005
    770
    Anyone know what table would pull -5 timing when you shift from park to drive? Doesn't do it in reverse or neutral.
    Stock:13.36@104
    Aug 2009
    Calibrating
    3,373
    Tune is mostly stock!!!
    14 Gen 5 Viper
