Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
Thread: Scanner Configuration & Histogram Repository
  1. #41
    Jul 2009
    Winfield/Ofallon MO
    599
    email support with your mpvi serial # and ask for the latest beta to be added to your download paage.
  2. #42
    Apr 2010
    Fort Wayne, IN
    eliminating knock?
    ok, so I have an 08 sky redline and im using the "LNF Generic 2.0L-aa10.cfg that i found on here to do my logging... on histogram 3 (Knock retard - Air Load vs RPM, knock retard) i have lots of little red cells ranging from 1-6.7 all over the place. I was reading somewhere else that i could just copy this table and do a paste special - subtract right into my spark advance table in my tune.... well i have 4 tables and am not really sure what the difference is between them. can i just do that into all 4 of them? sorry im new to all this.
  3. #43
    Aug 2007
    499
    Rather than pulling timing you should spend more time adjusting your fuel trims this has eliminated a lot of knock on my end.
  4. #44
    Advanced Tuner laser_racer's Avatar
    Jul 2009
    league city tx
    417
    This is just a basic P37 scanner setup just something for others to get started with.
  5. #45
    Tuner in Training -MD- HHR's Avatar
    Jun 2008
    Northeast Ohio, In the Lake
    40
    Quote Originally Posted by shabby View Post
    Here's another lnf config, its about as sorted/grouped as it can get. You'll need to add these 2 custom pids.
    Boost: Sensor - Manifold Absolute Pressure
    Function: [PID.11.PSI]-14.5
    LTFT+STFT: Sensor - none
    Function: [PID.6]+[PID.7]
    Fixed o2 b1s2 pid.
    Thank you for posting this.
  6. #46
    why would this be opening like this when i try to use this config? unsupported parameters on the tabs
  7. #47
    Feb 2009
    419
    2007 2.2 Cobalt.. I try to make parameters for it but they become unsupported. Anyone have a good conf file?
  8. #48
    Jul 2009
    league city tx
    417
    Some of the stuff you want to use is not available in the scanner yet. So you can do like I did and make then from scratch. What year 2.2? When I get home I will post my 2.2 scanner to help you get started. If anything says not supported it means just that your scanner is not setup for that car it needs to be reworked.
  9. #49
    Feb 2009
    419
    It is an 07. I tried making my own and still got unsupported, knock retard being one that comes to mind.
  10. #50
    Jul 2009
    league city tx
    417
    Here give this one a try. You need to add maf high and maf low to the table so you can log them to set the maf right.
  11. #51
    Mar 2011
    8
    Thumbs up
    Aight guys as many of you have already noticed LS1's are the default when it comes to the config files & histograms for the most part. Here you can post what configs have helped you along. Include in your post with this format:
    Year
    Make
    Model
    OS
    Vin
    What the config is for? Idle tuning, SD tuning, MAF tuning, General
    If your post is missing anyone of those it will likely be deleted since I need that info to verify its a working configuration.
    If you have custom histograms you'd like to post as well feel free. Same info is needed.
    NOTE: Do not open the .cfg or .hst files with anything but the scanner.
    The .cfg (configuration files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2 Directory
    The .hst (histogram files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2\Histograms Directory
    Here's an example
    2001
    Chevy
    Camaro
    12202088
    2G1FP22G412102986
    MAF Tuning/VE Tuning
    I5 Configs & histograms
    http://www.hptuners.com/forum/showpo...9&postcount=57
    http://www.hptuners.com/forum/showpo...0&postcount=58
    Thanks to NightriderCobaltSS from CSS.net for his help developing these two configs which will hopefully be included in one of the upcoming installer packages if all goes well
    They should work well for all 04-06 Cobalt SS's
    This can be used on most 4cyl e67 pcm'd equipped vehicles.
    This config was done by BennyHHR & im just posting it for him.
    To avoid any confusion these are NOT tunes, these are scanner config & histograms to be used in our scanner.
  12. #52
    Mar 2011
    8
    Can U Help Me ..chevrolet Colorado Turbo 2.9 4 Cylinder Turbo Gt35 ..injectors 65lbs Walbro Fuel Pump ..piston Low Compression 8.5 ..pauter Conecting Road ..i Need Tunning Asap Thank U
  13. #53
    Aug 2010
    28
    Hate to ask here,,,,,
    I'am lookin for a config file for a 97 2.2 (lnf)
    No wide band, no dyno, and real new to this.
  14. #54
    Jun 2011
    18
    is there a way to get a knock count in the tables as well?
  15. #55
    Sep 2006
    Phoenix, AZ
    398
    Quote Originally Posted by MoePwr View Post
    Cant you just change view in the histogram from average to total?
    Modular Muscle - Ford Tuning Source
    Ecotec-Tuning.com (check us out on upcoming episodes of "My Ride Rules" on Speed Channel)
  16. #56
    Jun 2011
    18
    my histograms arent even set up
  17. #57
    Advanced Tuner Japeatr's Avatar
    May 2010
    Dallas Texas
    252
    Hey im trying to setup MAF tuning with LTFT + STFT
    take a look at this and let me know if i have it correct.
    2.0LSJ: TVS w/2.9, 80s, E85, Dual Pass, Cobra HE, Injen Intake, 3" Catless exhaust, CIA midlength Header
  18. #58
    Jul 2009
    league city tx
    417
    This is how I set mine up.
  19. #59
    May 2010
    Dallas Texas
    252
    thanks Kendall ill give it a try
