Results 1 to 11 of 11
Thread: Configuration & Histogram Repository
    28,261
    Aight guys as many of you have already noticed LS1's are the default when it comes to the config files & histograms for the most part. Here you can post what configs have helped you along. Include in your post with this format:
    Year
    Make
    Model
    OS
    Vin
    What the config is for? Idle tuning, SD tuning, MAF tuning, General
    If your post is missing anyone of those it will likely be deleted since I need that info to verify its a working configuration.
    If you have custom histograms you'd like to post as well feel free. Same info is needed.
    Here's an example
    2001
    Chevy
    Camaro
    12202088
    2G1FP22G412102986
    MAF Tuning/VE Tuning
    NOTE: Do not open the .cfg or .hst files with anything but the scanner.
    The .cfg (configuration files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2 Directory
    The .hst (histogram files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2\Histograms Directory
    Feb 2006
    Canada
    1,958
    2000
    Pontiac
    Grand Am
    12201463
    1G2NV12E0YM867493
    Wideband Signal From EGR
    Attachment 4103
    This has the EGR v output signal set up to display AFR from 9-16 w/ the NGK Powerdex AFX kit.
    Histograms include AFR, AFR Error, and MAF Error%
    Chart will display Actual And Commanded AFR as well
    Paul
    28,261
    in the editor in the calibration details window or in an info log.
    Anyways heres a maf tuning config for grand prix & the like.
    Aug 2004
    Chandler AZ
    117
    Bill,
    I don't get it. sorry..
    I have a 1998 GTP & the AFX so I figured its time to configure this WB and I I'm not finding enough info to configure it intuitively.
    I can't open the attachments, I get an error message "cannot parse log".
    Can you direct me to a link or post that has some form of step by step "how to"?
    In the mean, I'll search and read thru some of these posts trying to finger it out.
    I need some HPT for dummy's.
    thanks,
    Best 60' = 1.716
    Best ET = 12.186
    Best MPH = 112.98
    28,261
    this is a config & histogram repository, you would need to open the file by either opening the histogram window & clicking the open file button or clicking the open config button respectively, its covered at length in our help file as well as the scanner quick start guide in the getting started section.
    -Bill
    Tuner awillis98's Avatar
    Dec 2007
    Port huron
    64
    thanks for the file for the MAF tuning for the GTP. i'm about 48 hours new to HPtuners. thanks. got anything else that will help me start tuning.
    ..."As I lay rubber down the street,
    I pray for traction I can keep,
    but if I spin and begin to slide,
    I pray dear Lord to protect my ride"! Amen.
    Apr 2006
    Hello,
    Tried to do MAF tuning on 97 camaro with a 3.8L, but the 'maf % error histogram' is not supported for my vehicle. Probably a stupid question, but does anyone have a MAF error histogram file that would work on a 97 camaro 3.8/Innovate LC1 wideband?? I also need HPT for dummies apparently. Thank you.
    John
    Quote Originally Posted by MMGT1 View Post
    2000
    Pontiac
    Grand Am
    12201463
    1G2NV12E0YM867493
    Attachment 4103
    Paul
    WTF? how come you only log ECT up to 120F???
    and how come everybody only logs Bank1 not Bank2? thanks
    Feb 2006
    Canada
    1,958
    Wow, this is an old one but I think you are looking a *C and not *F there. Also in a V-6 there is only one Narrow Band, hense the single bank being loged. You could weld a bung into bank 2 to use your WB to tune both sides of the exhaust though if you so desire. You would have to make use of the cycl skew table to make that work if inclined to go that route. You want to get real nuts you could weld a bung in each of your exhaust tubes and tune each one, but that would only be for a full out race car and not worth spending one red cent on IMO unless you are a world class runner... Just some info for anyone that may look in here guys
    Nov 2007
    28
    I know this is old but any clue as to why this don't work on a 2005 grand prix gtp????
    2005 Grand Prix Comp G, 180 tstat, KN intake, 3.6 pulley, pacesetter headers
    Hey Bill the grand am config isn't working and the stock v3 config won't log my 2000 grand am properly. Any help would be appreciated
