Results 1 to 8 of 8
Thread: COT Question
    Feb 2006
    Warner Robins, GA
    202
    COT Question
    I've noticed that my previous tuner had set the following COT parameters for the final car tune. Not sure if COT needs to be disabled or not or if there is a reason to leave it disabled.
    Here are my settings. Keep in mind I'm running Kooks 1-3/4 LT with Mettalic Hi Flow Cats.
    COT: Disable
    Max Enrichment: 1.07
    Temp Threshold 1: 2287
    Temp Threshold 2: 2215
    Temp Threshold 3: 2197
    Should I keep these the way they are?
    Thanks Chris
    2005 Pontiac GTO LS2
    MY FQUICK - http://www.fquick.com/cyclone_chris
    Mods:
    K&N Intake | 18" Staggered TSW Thruxton Setup | Toyo T1-R Tires | Billet Products Short Shifter | Kooks 1-3/4" LT Catted headers | NGK TR55 | Ported Stock Intake Manifold | Corsa Sport Exhaust | Polished T/B | FlowTech Streetsweeper V2 Cam | SLP UD Pulley | 160 Thermostat | LS7 Clutch | 39# Ford Blue Giant Injectors | Scorpion Roller Rockers |
    445 RWHP/413 RWTQ
    Feb 2006
    Warner Robins, GA
    202
    Anyone???
    Mods:
    445 RWHP/413 RWTQ
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Your COT is disabled as you have it, the temp thresholds and max enrichment are to tune the COT IF it is enabled (if you wanted to). I always just set the COT to disable and leave the other tables stock. Your ok the way it is.
    Russ Kemp
    Feb 2006
    Warner Robins, GA
    202
    Quote Originally Posted by Russ K
    Russ Kemp
    Having it disabled won't nuke my cats? I've had it running like this for 9 months now. lol
    Mods:
    445 RWHP/413 RWTQ
    Nov 2002
    Central Florida
    2,503
    If they're back in the Y a ways then you may live for a
    while although some blower cars have melted out Jet-Hot
    cats.
    There's no reason not to set max enrichment to your min
    PE table enrichment value; then COT will never bug you
    even if it kicks in. Just waste some fuel maybe.
    Dec 2005
    Regina, Sask.
    4,214
    jimmyblue,
    That sounds like a great idea, have you tested this?
    Russ Kemp
    Nov 2002
    Central Florida
    2,503
    I ran around that way for a good while, but once I gutted the
    cats I just disabled it. Like many things it's a compromise, a
    less effective (but think stock is "over-effective") protection
    for the sake of performance but still some.
    Feb 2006
    Warner Robins, GA
    202
    So what should I set them at? Or leave them disabled per the table above.
    Mods:
    445 RWHP/413 RWTQ
