Hey guys,
I'm having a problem with a 2001 GT that I'm trying to tune in. Car has an On3 turbo kit, PMAS HPX upgraded MAF, and DeutschWerks 78lb injectors.
The issue I'm running into is with the load based fuel and spark tables. I can't seem to get it to command a load greater than 1.0. I would assume that if this is a pressure ratio, on boost it should be over 1.0. The problem that this causes is that when the car goes into closed loop mode, it trims to essentially 14.0 AFR which is no good. I can circumvent this a little bit by extending the closed loop delay and using the MAF table to get a good mixture under boost, but only while in open loop. Eventually it always goes back into closed loop. And this won't really be a fix for ignition.
Can anyone help give me a crash course with this ECU?
Below are two logs. One open loop, and one closed loop. The fuel trims baffle me a bit, not sure if it really still trims in open loop.
TUNE_redo_test_0003.hpt
short_run_OL.hpl
short_run_CL.hpl
