I have a 5.3 swapped into a G35.
stock block
4.8 flattop pistons
706 heads ported
texas speed 224r cam
sheet metal intake with 102mm DBC throttle body
decapped gm flex fuel truck injectors (flow tested)
speed density tuning
First off, the car idles perfect and drives well at low throttle and will cruise around just fine. If you very slowly roll on throttle it will allow you to give it more throttle but as soon as you get to high rpm or WOT, especially when you stomp it, it cuts off as if you're hitting the brakes and bogs down.
I have tried all sorts of vm table modifications, as well as timing. No matter how much timing I pull, or how much fuel I add, it still knocks and cuts power when getting on throttle. I have also checked fuel pressure and it drops from 58psi to 50psi under throttle, but I cant imagine that would cut ALL power instantly. Nothing seems to change this. I have posted one of my logs below. I also changed the car to E85 to see if it stopped the knock, but it still has knock and the same issue persists. Any ideas?
5-18 run 1.hpl
