Hello, so I've been through the sticky on fans and spent a few hours searching the forum trying to find an answer on my own with no luck. I have a L99 out of an 11 Camero in a rock crawler project and I'm trying to get the fan set up to run PWM control using a C6 controller. ill attach a copy of the original tune and my current setup along with a log of a heat cycle. with current setup the fan desired % climbs with ECT as it should but I get no output from the PCM. Using a scope to monitor PWM output ECU connector 1 pin 58. If I put the original tune back in it it will bring the fan control circuit to ground. thinking maybe there is something i need o do with the state vs output or percent vs state charts but I cant find a known good file to look at. any help would be much appreciated, even if its just some guidance as to where i can find the correct training.
IMOR LJ updated.hpt
IMOR LJ.hpt
IMOR LJ fan.hpl
