Results 1 to 3 of 3
Thread: 4l60e to 4l80e segment swap
    Feb 2020
    Cincinnati, Ohio
    6
    Hello all,
    I am pretty new to hptuners. I am trying to help a buddy who has swapped his 4l60 for a 4l80 behind a 5.3. I am trying to locate a file I can use to do a segment swap but I am not finding the correct OS.
    His pcm is OS 1263008. Can anyone assist?
    13,588
    You can't.
    That is a 3 BAR OS installed on that computer. The segment swap must be done with the stock OS. So flash back to the stock file, perform the segment swap and then re-install the 3 bar OS and copy over all the tune information.
    Feb 2020
    Cincinnati, Ohio
    6
    Thank you
