Hello, new to this and need a bit of help. I am doing a turbo 4.8 in a truck. The motor is fresh and has a SS2 cam in it. Currently the turbo is not hooked up yet as I am still working on the plumbing. I loaded up a base speed density tune (3 bar Map on the P59 ECU, Deka 80s, SS2 cam, 7875). I know it doesn't have the turbo setup, but I figured idle with turbo or without is similar and should work?
It fires up nicely, but after about 30 seconds it throws P0106,P0107 and P1514 and completely dies. The 1514 table is maxed too. I am also having throttle issues with the DBW. If I hit the throttle quickly it throws code P1518 and also dies right away. The battery was very low and I had to boost it, so that could be the cause, but what else should I check? The truck ran and drove perfectly before freshening up the motor.
Likely have some things wrong tune wise, my main goal is to get it running roughly and take it to be properly dyno tuned.
