The stoich affects the commanded part throttle & pe afr, so put it back to 14.7, as the closed loop afr will move leaner & richer than 14.7. This is normal. The stoich afr table is referenced to the % of alcohol if you have a dual fuel option car. You can set the whole table to 14.7 if your using gasoline only.
Russ Kemp
