99 TA
6.0 bore 30 over
243 heads with valve spring upgrades
LS6 intake with stock size throttle body, 72mm I believe
BTR stage 2 turbo camMy 1999 TA MAF tuneing #6 back to stock injector values.hpt
TH350 RMVB with brake, no engine braking
I tuned the car with the stock 20 something injectors and it ran like a raped ape up to 4000 RPMs then fell on its face, injectors were maxed out. Installed a set of 72s and adjusted the injector tuning with the values supplied by FIC. Now the idle is horrible, stumbles on tip in, and runs extremely lean. I'm lost.
I know that I have missed something blatantly obvious but can't find it. Can one of you excellent gentlemen/ladies look at this tune and tell me what I've missed. I know its injector related because she was dead on prior to the injector change. Just cant find my issue.
I currently have the tune setup for MAF tuning.
