98 pcm, ls2 based 403. Runs great and I have the SD tune pretty dang spot on. The problem I?m having is I have to cycle the key (fuel pump) at least twice for the car to crank. If you try to crank it on the first key cycle, it just spins over with a pop through the exhaust every now and then. If you cycle the key twice, it usually fires right up. This issue is happening hot and cold starts. Issue just started when I changed fuel rails and went from a fast 102 intake to a single plane super Vic with 4500 accufab throttle body. What?s up? I?m guessing not enough prime pulse mass for the big single plane intake. Any help thanks.
