1st:
Check your roll-out in inches.
Mark the tire & the ground (at nomal tire temps after driving).
Rotate one or two revolutions (divide that value in inches by 2 if you do 2 revs
). Then mark the ground where the tire mark makes it's 1st or 2nd revoltion. It should be ~88.18" If it's different, time to rescale.
Here's the math on how to do the speedo rescale:
Tire revolutions/mile = Inches per mile / Tire Circumference Inches
Tire Revolutions/mi = 63360 / 88.18 --- based on (28.07" tire * Pi)
Trans revolutions/mile = Tire revolutions/mile * Gear ratio
Your values:
(63360" per mile / 88.18" tire circumference) * 4.56 gear = 3276.33
Take that value and multiply by the Rev-Trans value (40 in *most* cases) to get the VSS Pulses/mile = 131053
Put your values in the appropriate places and your speedo's dead on. Check with a GPS if you have doubts.
EC
