Thread: Changing/adjusting commanded eq
    Aug 2019
    12
    08 tbss turbo 408. Took it out for maiden voyage and some data. At low speed or cruise situation, my commanded eq ratio is about .85 and I'm tuned pretty close with +/-5% or so right now. However, shouldn't my commanded be somewhere around about .95-1.0 for idle or part throttle? How would I go about getting the commanded value dialed in so I'm not chasing my fueling on a rich cmd situation?
    13,565
    You didn't set your open loop EQ ratio to 1.00 for intake valve temps above like 100-130 degrees. This is why it won't command stoich like it needs to.
    Aug 2019
    12
    Thank you. I was diggin through it all and saw those tables. It was just a base tune from a buddy with a similar build. So I'll try that maybe today. Thanks again
