Results 1 to 10 of 10
Thread: generation 4 MAF, I cant seem to get this e38 out of VE mode
    Aug 2020
    16
    I've tried every thing I can find to disable VE tables. Taking Huge swings at MAF tables and not changing A/F ratio. I wonder what I'm missing?
    Post up your tune file
    Aug 2020
    16
    try this
    Dec 2018
    Washington State
    182
    dump your dynamic airflow tables,to run maf only
    Oct 2013
    550
    Quote Originally Posted by Larry Reed View Post
    Given the tune that you posted, you have no idea what you are doing.
    Bad things will follow if you do not self-educate before making changes to your calibration.
    There are many, many tutorials available on the internet on the topic of "How to tune an E38 ECM".
    Start reading.
    Here is a photo of your current MAF settings - the E38 will only run on the MAF Sensor data above 4000 RPM.
    Proper settings to always run on the MAF Sensor data are depicted in the "pink" boxes.
    Aug 2020
    16
    Quote Originally Posted by Jon S. View Post
    Start reading.
    thanks for your reply, its obvious I,m in over my head. If i set high rpm disable low, it hates life and wont "really" run. PIG rich. No matter what i throw at it with MAF. I have replaced the MAF sensor hoping it might resolve the issue, but no luck. FWIW, Maf is right about 3500 hz at idle.
    Oct 2013
    550
    Is this a conversion project ?
    If so, there are about four mainstream MAF options - three "tube" style MAFs, and the always popular LS3 / LS7 "blade" style MAF.
    All require different base programming.
    The tube style MAFs are reasonably forgiving regarding their placement in the air intake piping.
    The LS3 / LS7 MAF needs to be very specifically placed - exactly straight in the pipe, exactly on the pipe diameter (or centreline), away from any bends in the pipe, and away from the throttle body. GMPP (CPP) instructions list 6 inches as the minimum length of straight pipe required - with this MAF placed dead centre (3 inches of straight pipe on either side). From experience, I prefer the straight section of pipe, with the MAF in the middle, to be at least 8 inches in length .
    If you do not adhere to the above, the MAF Sensor data will likely end up being erratic.
    Aug 2020
    16
    I put the high rpm disable/reenable to where you recommended, installed factory air cleaner and ended up with about half the MAF airflow vs frequency, still on .75 to .80 lamda.
    Australia
    1,984
    u need to have a populated VE table as it always gets looked up, ur never truly MAF only, are u adjusting the maf values to suit or just changing intakes ? if u want to see if u can adjust low enough just zero out the maf table and it shouldnt run for long after startup, then u know all u have to do is adjust the values to suit
    Aug 2020
    16
    Kind of the answer I was looking for! Thanks
