Results 1 to 13 of 13
Thread: Injector data help
    Dec 2020
    6
    Injector data help
    Can anyone point me in the right direction to the injector data file for GM 12613412 injectors to change the tables in HPtuners?
    I have a base tune that got my swap running but I have a Sloppy stage 2 cam and these larger injectors with a TBSS intake.
    The data I found is not correct or so it seems, as the car will die after coming off high idle.
    Thanks for any and all help
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Total guess here...
    Find what vehicle those injectors come in stock. Go to the Tune repository, download a tune for that vehicle and compare the injector tables.
    Do you have a Wideband? If so what is your AFR? If its in a reasonable range you might want to look else where...
    Also
    You will get much better responses here (from people much more knowledgeable than I am) If you post all info on your vehicle and post up a tune for them to look at.
    2011 Camaro 2SS Convertible L99 Bone Stock for now
    2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
    13,606
    Find a stock tune with those injectors. So like a express van or savanna van that came with those 50lb/hr injectors. A flex fuel heavy duty truck would be okay as well.
    Then you need to put that data into a spreadsheet to convert the LS3 injector data into the LS1 format. You posted in the GEN 3 section so I assume this is what you require.
    Dec 2020
    6
    Thanks guys, I will work on updating the post with all the data and my tune file. I was able to find what I thought was the converted injector data from the lt1 site, but plugging that data in, still netted the same stuttering idle/shutdown results.
    Dec 2020
    6
    I can't view the attachment you sent
    Sorry i just couldn't view it on my phone, works fine from the laptop
    Dec 2020
    6
    Thanks again guys
    I have attached the tune that is working in the car but is rich and stalls at stops. It looks to have 24lb injector data in it. I am running the GM 12613412 injectors and either cant get the correct data for them or the data wont work with the tune.
    My swap specs are as followed:
    69 Nova
    LQ9 Swap
    Sloppy Stage 2 Cam'
    Pac 1218 Springs
    Longtube headers
    TBSS intake w/78mmTB
    TH350 W/3500Stall
    Thanks for any help guys
    13,606
    Did you use the spreadsheet?
    Copy the 50lb/hr injector data into the spreadsheet and it will convert it for you. Then paste that data into your tune.
    The MAF and VE will be a ton of work, they don't look good and your are asking for way too much timing on a 6.0 with a camshaft. It doesn't need 31 degrees of timing, maybe more like 25-28 degrees.
    Dec 2020
    6
    I will try that when I get off shift tomorrow and report back. Any tips on what I can do with the MAF and VE tables?
    Thanks for your help
    Jul 2020
    tn
    40
    Quote Originally Posted by Nova_4951 View Post
    man went thru the same shit found 6 tunes all different all the values..
    sio i wne thru all 6 programs and averaeaged allt he file s and used them
    so now i need to find those files./.arghh
    Jul 2020
    tn
    40
    worse can i can send u my tune
    Jul 2020
    tn
    40
    here ya go..
    yowillhave to look thru and you can figure out hwat values i used.. put allthe values in form all the sources i foundBook1.xlsx
    Dec 2020
    6
    thank you tnbubba. I'll get busy on it today
    Mar 2017
    3
    Trying to find this injector spreadsheet. Have been using search with no luck. Thanks
