Results 1 to 7 of 7
Thread: gen4 E40 5.3l getting false knock?
    Sep 2020
    Northern Indiana
    26
    vehicle is 06 buick rainier, sbe 5.3, tick performance towmax stg2 cam, tbss intake manifold, full dual exhaust, pump 93
    i built the exhaust myself and i know i have some areas that are especially tight and may contact the frame, so some false knock is expected, however, logging today, i see that i got 6* at mild throttle randomly, yet get 0* at 80% throttle. including current tune and latest log file.
    should i be looking at spark tables or something else? seems to happen at random at low throttle. it happens early in the scan.
    also, havent touched my ve tables because when i fail the maf to go sd, the trans shifts terribly and im not trying to blow up my transmission. t42, 4l60
    thanks in advance guys.
    2009 Pontiac G8 GXP M6 416 twin turbo LS3 stroker
    1007 rwhp, 1056 rwtq. Justin White tuned
    2006 Buick Rainier 5.3 awd> Tick performance towmax stage 2
    cam 214/224 | .571"/.561" | LSA114+4, tbss intake manifold,
    full dual exhaust ???rwhp, ???rwtq. Tuned by me
    Are you using a wideband? Tune the maf, first. It's easier. Be easy because the knock may be real. When you log see where the knock is and look at at the afr if its lean add some fuel.
    Sep 2020
    Northern Indiana
    26
    The maf is tuned, I just haven't done the ve table yet because the ruck shifts like shit when I disable the maf
    7,649
    Quote Originally Posted by bug View Post
    Sep 2020
    Northern Indiana
    26
    Gotcha, I didn't even know that was there. Thanks
    Oct 2020
    23
    What exactly does the TCS patch do or have to do with his shifting? Just trying to learn here as I'm first time tuning my LS3 and I haven't selected that patch.
    7,649
    Allegedly, the TCS Patch causes it to not trip the 'invalid torque' signal which is the thing that's maxing out the line pressure when the MAF goes missing.
    You can also look at Trans Diagnostics > General > Invalid Torque Signal: Max Pressure [enabled/disabled]
    or just apply the patch and see what happens. It won't affect anything after it's back in blended mode.
