tuned SD OL with a wideband, enabled LTFT with MAF still disconnected just to check stuff out..WOT LTFT are +5 driving AFR down to the high 11's...how am i suppose to fix this ?
Why do you have LTFT's at WOT?!
Did you disable PE?
Always Support Our Troops!
i give up why ? no
Need to look at your commanded AFR and actual AFR (if using a wideband) Hi MAP fueling is obviously high or COT enabled.
filtered to >80% throttle position
Post your log & tune it helps greatly..
how ?
hold on
try this
was tuning in OLSD, i just turned the LTFT and closed loop on to see where eveything would fall....thank you for your time
car seems to run better at very throttle/ low load settings now with your tune, but i have a "Service Vehicle" light on now, also with all the tweakin i've been doin with LC1, I've dicovered it has been to the default LC1 pid and I'm using a User Defined pid, i guess that's why my readings are all messed up... set LC1 to default settings as well as using HPT defualt LC1 pid and all is well as far as the wideband goes..boy is my face red, i was getting pretty frustrated there for awhile...thanx for all the help
