Results 1 to 13 of 13
Thread: jtec 1996 failed load tune , now dont start
    Tuner in Training Tobbe1's Avatar
    Jun 2012
    41
    jtec 1996 failed load tune , now dont start UPDATED !
    1996 1500 ram made a small adjustment and try to load a tune looks ok untill aprox 50%
    and everything stop . says failed .
    do i need a new ecu? or a hptuner software fault? (have a ticket send to hp tuner but no reply so far).
    UPDATE! truck is running , in beta editor is says power off/power on but waiting 20sec before power on and a good internetconnection make it write.
    Just reload the stock file. You'll be fine
    Jun 2012
    41
    stock tune dont work , going to 50% then same fault massage
    May 2020
    Disconnect the battery for a few minutes reconnect and retry. I was running into this issue every time doing back to back flashes. This took care of my problem.
    Jun 2012
    41
    Quote Originally Posted by Jcord View Post
    sorry tried that ..now it only try 30% ..before failed. try to read my dakota jtec+ and it dont read only connect and i can se ecu info.
    obd scanner dont work on any vehicle i tried so far i can read vehicles thats all.
    Quote Originally Posted by Tobbe1 View Post
    did you try disconnecting the battery and leaving it overnight
    Jun 2012
    41
    Quote Originally Posted by malikib View Post
    only for a few hours
    Jun 2012
    41
    HP tech says they working on it , no reply so far.
    Sep 2020
    same thing just happened to me
    Jun 2012
    41
    to bad , got no solution from HP tuners , got a used ecu from a junkyard to get my truck running for now .
    Jun 2012
    41
    truck is running se first post.
    May 2015
    1,908
    this is #7 inside of 8 days of failed writing, not good, something is amiss in the latest versions of vcm suite.
    823
    Yep.
