Anyone able to Cross Reference these fuel Injectors?
Good day fellow tuners...
I have a 06 SSR to tune, as the current tune is giving the current owner problems.
Owner recently purchased the vehicle.
I have attached a photo of the fuel injector.
Here is the Injector Info...
Siemens Deka
EDGE Products
961 M000200
6049P05394
In the tune....
Injector Flow Rate vs. KPA VAC
lb/h 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 kPa
Flow Rate 63.5 63.5 63.5 63.5 63.5 63.5 63.5 63.5 63.5 63.5 62.8 62.4 61.9 61.5 60.5 60.5 60.1
^^^ numbers above are useless as this is the lovely E40 Pcm and hard coded at a max value of 63Lb/h. ^^^
I contacted Edge Products, they confirmed it was their product. But since it was more then 14 years ago they have unknown information or can not find any information to help. So this has become a lost cause.
I googled the numbers, i am not having anyluck.
Does someone have a master fuel injector cross reference sheet or something they are willing to share with me please and thank you.
Maybe someone has delt with this before. Please chime in. I only post if ive reached the end in needing serious help.
SSR mods....
I know its supercharged, with a cam and exhaust. 6.0L
If I had to guess, and it seems like there isn?t a whole lot of options left, I?d guess they are Siemens Deka 60s P/N 107961 which possibly explains the 961. That would mean your options are scaling, adjusting Stoich and matching the relationship to IFR or reduce base fuel pressure as 107961 injectors are greater than 63.5 @ 4 bar.
Hope that helps
