Logged a NOS pass WOT is only 79%, why?
We are dialing in a 2005 H/C C6 with spray and logged the following log. I know that the reported TPS is usually 88% at WOT but why is this car reporting no more then 79%??
Is there anything with the 05's where the PCM decides to back throttle opening to a certain max value?
Is this not an issue?
Next post will have attachment...
You need to monitor ETC position not TPS.
You need to log ETC position %, not TPS SAE on your car.
Russ Kemp
I figured they where different but I always at least remember seeing in max at 88%. I'll change the PID.
