Thread: Compression change
    Compression change
    All things being equal, what all would you touch in a tune if you simply bumped up compression Ratio? VE and timing?
    13,565
    Possible changes in commanded air fuel ratio under full throttle and ignition timing.
    No VE tuning, or just those would be your top 2 with VE still possible?
    13,565
    That can be gone over if it needs it.
