Results 1 to 6 of 6
Thread: 4L60 to TH350 Conversion
    May 2006
    28
    I am almost done with putting a turbo 350 in a friends 99 Camaro and was wondering what needs to be done with the tune stuff and codes?
    Can i just zero out the trans tables and turn the trans codes off or is it more to it?
    Jul 2004
    1,579
    Actually, there is less to it. You can leave those tables populated, as they will no longer do anything. You just need to turn off all of the trans DTC codes off (P07xx). One thing though, if he will be using a speedo (Electrical VSS), you will need to verify that the TH350 drive/driven gears are correct for his application. Then simply use the Electric VSS found on newer (IIRC 1991 and newer) vehicles. Splice into the NSS switch and you are good to go.
    May 2006
    28
    Two questions,would the rev limiter change with the check engine light on with the tranny codes and is there a speedo sensor that works with the old gear setup on the TH350?I was thinking about taging into the front wheel sensor for the speedo.
    Jul 2004
    1,579
    You can use the front wheel sensor apart from the trans VSS. If the ECM is throwing a Baqd VSS Signal code, you will need to match the rev limiter from that table to your desired rev limit.
    Tuner TexasGMC08's Avatar
    Feb 2013
    Fort Worth
    102
    did a swap in a V6 4L60e to V8 TH350 and speedo is off can you shin some light on the fix??
    JRXTuning & Performance
    Fort Worth Texas
    [email protected]
    2011 CTSV https://youtu.be/WUuGxYNfJjk
    2008 GMC Sierra 5.7, Nitrous Outlet 200shot, 4.10 gears (Sold)
    2007 GMC Sierra 4.8 4/7 drop, Tune only
    2007 CTS-V BTR STG4,TFS225,MSD Airforce,102NW TB
    Advanced Tuner Ranger6202's Avatar
    Oct 2013
    Wyoming
    346
    Work from the back towards the front........Find revolutions per mile of your tire size, multiply that by your gear ratio to give you drive line revolutions per mile. With a generic VSS that will be located in the tail shaft, all you'll need additionally is the Pulses per revolution (teeth on reluctor wheel). If you have a pulse generator that is inline with the cable speedo, you will have a reducing gear off of the drivetrain. You'll need to find/figure out that ratio difference of that little gear to figure out your actual VSS pulses per revolution).
    Custom '85 Crew Cab Short Bed Lq4 swap
    '06 Turbo Vortec Maxx
    '87 Military K3500 LQ4 swap
    '96 K1500 lq4 swap, Howard Cam (216/224 @ .050, .551/.551, 114), Centerforce Dual Friction
