any more tables for 4L65e with a LS2 in front.??? Or how about trans oil temp?? Shift timing to make them quicker???
2009 G8 GT ... stock... DD
2005 GTO A4 (heads and cam ) currently broken.... last time 12.4 @ 109 (just a TC)
Sold: 2001 Chevrolet 2500HD 4X4 8100 vortec RCLB [email protected]
NO love here
The 2005 GTO has the Force Motor tables, Shift Pressure, Max Pressure and all the TCC tables that you need to firm up the shifts and get rid of the TCC slip.
If your shift pressure and force motor tables are set up right, the desired shift time table is not really needed. I've left that table stock on different vehicles, and the shifts are firmer & quicker because of the changes to the force motor & shift pressure tables.
I've seen the desired shift time as high as .750 sec. on a 1997 LT1 Camaro. This would be the MAX allowed shift time before the shift adaptive strategy would be enabled (increased line pressure). Of course the trans shifts were under .750 sec.!
Russ Kemp
But in order to setup the FMC tables I need trans temp to work since its based on trans oil temp. which now logs as 32* all the time.
How shifting through a locked converter?? yes I now you need one built for it.
Plus also is there a way to make the act of downshift quicker?? Yes I change the speed at which the downshift occurs, but how about making the gear change quicker?
