Not at this time.
Not at this time.
Anything on the 2000 V10 in the works?
HPT may support it in the future. If you need something now, you could buy a single license SCT Advantage PRP package.
Formerly known as RWTD
Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
I would really like you guys to keep up with us older owning trucks. We wait and you just keep working on the newer ones, as we continually sit here waiting.
I have a friend that has your unit and software I can read my file and sent it if it would help speed our cause along.
Ford 1999 F250 Superduty v10
Scott
I doubt it will read that particular pcm (EEC-V). I'm fairly sure it only reads PowerPC based vehicles at this time.
OK, So its been 7 years since the last post on this topic. But am i ever going to be able to use my beloved HP Tuners on my recently added F350 6.8 Liter V10. The last thing i want to do is send anymore of my money to SCT. Ive already made that mistake one and will never do it again.
99 silverado 1500 5.3, 30 over, all new ported, polished, and milled heads 30 thou, 220 226 custom BEI cam. 2" intake valves, ported & polished TB, Long tube ceramic coated headers, magna flow cats, y pipe, 3" magnaflow, vera ram air intake, I6 TB stall, All new Drivetrain, 3 Trans coolers, Auburn E-Locker, 4.56 gears, Throttle body bypass, Flex-a-Lite E-Fans, LS1 e-fan harness, ASP Under Drive Pullleys, HP Tuner Pro. 1 Bar MAP SD OS upgrade. Amsoil EA Bypass Oil Filtration system.
