Results 1 to 10 of 10
Thread: LC1 offset question
    Dec 2005
    Texas
    254
    LC1 offset question
    LC1 output voltage only 4.90v, so I use 4.90v for the offset formula since i'm not getting the full 5v right ?
    Señor Tuner MeentSS02's Avatar
    Jun 2005
    Dayton, OH
    1,132
    I'd only use data points between 1-4V - anywhere at the edges tends to get clipped.
    2008 Viper - now with HPToona - 1/4 Mile Shenanigans Here
    11.02 @ 130
    Dec 2005
    Texas
    254
    so set up LC1 to output 1v=10 AFR, 4v= 18AFR ?
    Jun 2005
    Dayton, OH
    1,132
    Nah, I'd still set it from 0V = 10 AFR and 5V = 18 AFR, but wouldn't expect it to be accurate at either 0 or 5 volts just due to clipping. So if you are finding the offset, find what the offset is at like 2.5 or 3 Volts...somewhere in the middle that isn't at the extremes.
    11.02 @ 130
    Sep 2002
    Chicago, IL
    6,394
    on mine I think I'm using 0.5-4.5 12afr-18afr
    We got this guy Not Sure, ...
    Dec 2005
    Texas
    254
    programmed LC1 for .5v=10 AFR, 4.5v= 18 AFR...getting 4.36v at input to EIO but showing 4.42 raw voltage in HPT..how the hell does that happen ? I'm gainin voltage instead of loosin it ?
    Dec 2005
    Texas
    254
    and for the love of God someone please confirm the wiring of LC1 to HPT...currently have :
    Analog out to EIO + input
    System and Analog gorund wired together going to EIO ground
    Using switched 12v form fuse panel
    Heater ground to pass head ground
    Dec 2005
    Texas
    254
    commanded flatline 2.5v....gettin 2.4 at EIO input, 2.45 in HPT....what's goin on ?
    Oct 2006
    6
    Quick question on the scaling of the preconfigured PID that comes with MPVI Pro that is setup for the LC-1 wideband(Analog Out 2)? From the factory the LC-1's Analog Out 2 is programmed to output 0V=7.35 and 5.0V=22.39 afr. What is the PID in MPVI Pro scaled for?
    Thanks in advance.
    Dec 2005
    Texas
    254
    default LC1 PID matches default LC1 programming
