Car has intake only, and a street tune. During the maf and vve calibrations, the afr staying pretty much where I was expecting at 10.7:1 at wot(what it did bone stock). Now that I have the o2's and closed loop enabled, it will run 9.8:1 or so at wot even though commanded is leaner. I noticed it does it as soon as it goes into open loop, around 3500rpm. The STFT stops reporting and the commanded afr goes rich. I adjusted the pe table in that rpm range to redline from the stock 1.37 to 1.32, trying to lean it out a little, and it did nothing. Do I need to edit the open loop table to fix this? I'd like it somewhere 11.2-11.5:1. Log and Tune file attached. The very last wot run in the log is the easiest to see this in.
Thanks.
