Results 1 to 5 of 5
Thread: 2010 e38 ecm VE SD mode?
    Advanced Tuner =fast='s Avatar
    Jan 2009
    396
    I have a 2010 e38 ecm and would like to go VE SD mode I see this year don't give me the option like the 2009 Main VE or apply the 2 bar SD mode.
    Would the VVE work good in Open Loop SD? Or there's a way to go with the Main VE?
    13,582
    Yeah, you could still do VVE open loop speed density.
    If no 2 bar OS is available, you can't do anything about it.
    Actually, I was able to do a write entire on my e38 to another e38 file that did have the 2BAR SD option. Worked fine. All, I had to do was change the vin in the scanner. If I remember correctly, someone had a thread on here with a list of compatible e38 operating systems.
    13,582
    My point was that if nothing is available on that file, you are shit outta luck.
    There are other work arounds if you so choose.
    Jan 2009
    396
    Thank you will try it out.
