Results 1 to 7 of 7
Thread: want to run closed loop but wont
    something is keeping me from running closed loop. I must have missed something. would someone take a look and see? (the short section in closed loop was forced using the scanner) THANKS
    Also does anyone know how to get access to the pressure sensor settings in a FSCM? I'm getting a P2635 after installing a 450 fuel pump
    13,595
    What is the passenger side o2 sensor doing?
    You are not logging it, so I don't know if it's even working.
    You set all your o2 sensor codes to no error reported, that isn't smart if you ever want to know if you have a problem with the sensors. Both must be working to allow for closed loop.
    Sorry u may need a lil info, single turbo only using driver's side O2 sensor 1
    There are only 3 DC tables on the FSCM, is this right? How can I get access to the other tables? This is an 08 Silverado
    13,595
    My first post has your answer. You need both primary o2 sensors for closed loop. Otherwise it's open loop forever.
    I can't help with the FSCM question.
    Wow did not realize that, thanks
