Results 1 to 5 of 5
Thread: LS2 SD and auto transmission shift pressure...
    Tuner barkingspud's Avatar
    Mar 2006
    NW Burbs of Chiraq
    119
    So, is the issue fixed (or a workaround in place) when I disable the MAF on an LS2 the auto trans shift pressure goes max? I tried searching but probably didn't search on the right terms.
    TIA,
    Mark
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    http://www.hptuners.com/
    bottom left hand side.
    Mar 2006
    NW Burbs of Chiraq
    119
    Duh!! Thanks Bill. So, how to I invoke the feature to disable full line pressure when failing the MAF?
    HP Tuners Support
    (foff667)
    28,268
    its probably under trans diag as with LS1's with similar issues...I'd need to look at the file to be sure though.
    Mar 2006
    NW Burbs of Chiraq
    119
    Found it.....Now on with the SD tune....
