Hey guys I'm starting to tune my first turbo setup. Tried using a few base maps to no luck, so bit the bullet and took my stock OS to a 2 bar, put in my deka 80 injector info, turned off MAF, LTFT/STFT. Put in a good timing table and started doing some 110KPA and lower tuning with AFR vs comm. adjustments. What I'm finding is I havent went over 3K yet and have cells over 100 to get to 14.68. Is this common? Is it something im doing different? Every file Ive viewed to compare has had what I would consider normal ve numbers, definately not over 100 until 110kpa+ area.
Setup is a stock 6.0 78/75 turbo, deka 80s.
