I've attached my current tune file and a scan of a WOT street pull. The car spins through 2nd after the 1-2 shift and I'm not sure if that is what is causing this (if I got WOT from a rolling start, same extremely early shift points)
Car is shifting VERY early compared to the commanded RPM AND MPH. I have ALL shift schedules matching in the tune trying to figure this out.
Transmission is out of a HD truck (fleet vehicle/box truck I was told)
Stock converter
NA 408 420/420 on the dyno
Vehicle speed is correct/verified
Trans torque is verified via logging/comparing on dynoStreet WOT test 5.hplRound 2.hpt
